- 4.199,00 €
- Nuovo
- Negozio
- Tipologia
- Altro
- Taglia
- M
- L
- XL
- Materiale telaio
- Alluminio
- Classica/elettrica
- Elettrica
- Madrid Madrid, Spain
C:62 Monocoque Advanced Twin Mold Technology, Aluminium 6061 T6 Rear Triangle, Efficient Trail Control, FSP 4-Link, Agile Trail Geometry, Boost 148, UDH, Full Integrated Battery, Advanced Internal Cable Routing
SIZE
M (18"), L (20"), XL (22")
FORK
Fox 38 Float Performance GRIP, 3-Position w/Micro Adjust, Tapered, 15x110mm, E-Bike Tune, 170mm
SHOCK
Fox Float X, 205x65mm, Trunnion Mount, Adjustable LSR w/ 2-Pos. Lever
SHOCK HARDWARE
Top: 54mm Trunnion Mount, Bottom: 22.2x8mm
DRIVE UNIT
Bosch Performance CX New Smart System 2022
BATTERY
Bosch Powertube Battery 750W
DISPLAY
New LED System
CHARGER
New compact Charger
BRAKE SYSTEM
Magura MT7, Hydr. Disc Brake (203/203)
REAR DERAILLEUR
Sram GX Eagle, 12-Speed
SHIFTERS
Sram GX Eagle Trigger, Single Click
CRANKSET
ACID E-Crank, 165mm, 36T
CHAIN GUIDE
Reverse Flip-Guide E-Kettenfhrung, Direct Mount, GEN4
CASSETTE
Sram XG-1275 Eagle, 10-52T
CHAIN
Sram NX Eagle
WHEELSET
Newmen Performance 30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless Ready
FRONT TIRE
Maxxis Assegai, MaxxGrip/EXO+, Tubeless Ready, 2.5 WT
REAR TIRE
Maxxis Minion DHR II, MaxxGrip/DoubleDown, Tubeless Ready, 2.4 WT
STEM
CUBE Performance Stem E-MTB, 31.8mm
HANDLEBAR
Newmen Evolution SL 318.25, 800mm
GRIPS
ACID Disrupt, Soft Compound
SEAT POST
CUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm (M: 125mm, L,XL: 150mm)
SEATCLAMP
CUBE Screwlock Semi Integrated, 34.9mm
SADDLE
Natural Fit Venec
HEADSET
ACROS AZF-1035, ICR (Integrated Cable Routing), BlockLock 120°, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm)
WEIGHT
24,5 kg
SIZE
FORK
SHOCK
SHOCK HARDWARE
DRIVE UNIT
BATTERY
DISPLAY
New LED System
CHARGER
New compact Charger
BRAKE SYSTEM
REAR DERAILLEUR
SHIFTERS
CRANKSET
CHAIN GUIDE
CASSETTE
CHAIN
Sram NX Eagle
WHEELSET
FRONT TIRE
REAR TIRE
STEM
HANDLEBAR
GRIPS
SEAT POST
SEATCLAMP
SADDLE
Natural Fit Venec
HEADSET
WEIGHT
24,5 kg
