Frame | S-Works Diverge FACT 11r carbon, SWAT™ Door integration, Future Shock suspension, threaded BB, internal routing, 12x142mm thru-axle, flat-mount disc |
Fork | Future Shock 2.0 w/ Damper, Smooth Boot, FACT carbon, 12x100 mm thru-axle, flat-mount |
Saddle | Body Geometry S-Works Power, carbon fiber rails, carbon fiber base |
Seatpost | Roval Terra Carbon Seat Post, 20mm Offset |
Stem | S-Works Future Stem w/ Integrated Computer mount |
Handlebars | Roval Terra, carbon, 103mm drop x 70mm reach x 12º flare |
Seat Clamp | Specialized Alloy, 30.8mm |
Bar Tape | Supacaz Super Sticky Kush |
Rear Brake | SRAM Red eTap AXS, hydraulic disc, 160mm CenterLine XR rotor |
Front Brake | SRAM Red eTap AXS, hydraulic disc, 160mm CenterLine XR rotor |
Chainrings | 42T |
Shift Levers | SRAM Red eTap AXS |
Crankset | SRAM Red 1 AXS |
Rear Derailleur | SRAM XX1 Eagle AXS |
Cassette | SRAM XG-1295 Eagle, 12-speed, 10-50t |
Bottom Bracket | SRAM DUB BSA 68 |
Chain | SRAM XX1 Eagle, 12-speed |
Front Wheel | Roval Terra CLX, 25mm internal width, 32mm depth, 21h, Tubeless ready, DT for Roval hub, Centerlock disc, DT Swiss Aerolite spokes |
Rear Wheel | Roval Terra CLX, 25mm internal width, 32mm depth, 21h, Tubeless ready, DT for Roval hub, Centerlock disc, DT Swiss Aerolite spokes |
Rear Tire | Pathfinder Pro 2BR, Tan sidewall, 700x42 |
Front Tire | Pathfinder Pro 2BR, Tan sidewall, 700x42 |
Inner Tubes | 700x28/38mm, 48mm Presta valve |
