- 7.550,00 €
- Nuovo
- Negozio
- Tipologia
- Altro
- Taglia
- S
- M
- L
- XL
- Materiale telaio
- Carbonio
- Classica/elettrica
- Elettrica
- Madrid Madrid, Spain
E-Bike
MotorSpecialized Turbo Full Power System 2.2 Motor
UI/Remote
Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, ANT+/Bluetooth®, w/Handlebar remote
Battery
Specialized M3-700, Integrated battery, 700Wh
Charger
Custom charger, 42V4A w/ Rosenberger plug, 100-240V
Wiring Harness
Custom Specialized wiring harness
Frameset
FrameFACT 11m full carbon, 29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel, geo adjust head tube, geo adjust horst pivot
Seat Binder
Alloy, 38.6mm
Suspension
Rear ShockFOX FLOAT X2 Factory, LSC, LSR, 2-position lever, 55x210mm, Kashima
Fork
FOX FLOAT 38 Factory 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 160mm travel, Kashima
Accessories
SWATSWAT CC steerer tube integrated tool with chain tool and link
Cockpit
SaddleBridge, 155/143mm, Hollow Ti-rails
SeatPost
RockShox Reverb AXS, 30.9, 1X remote, (S1:100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
Stem
Deity, 35.0mm
Handlebars
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
Grips
Deity, Knuckleduster, Black
Brakes
Front BrakeMagura MT7, 4-piston caliper, hydraulic disc, 203mm rotor
Rear Brake
Drivetrain
Shift LeversSRAM Eagle AXS Rocker Paddle
Rear Derailleur
SRAM XX1 Eagle AXS
Cassette
Sram XG-1299, 12-Speed, 10-52t
Chain
SRAM XX1 Eagle, 12-speed
Crankset
Praxis Carbon/Custom Offset/ISIS Spindle Interface, 160mm
Chainrings
SRAM X-Sync Eagle, 104 BCD, 34T, steel
Wheels & Tires
Front WheelTraverse SL 29
Rear Wheel
Traverse SL 27.5
Front Tire
Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.6"
Inner Tubes
Standard, Presta Valve
Rear Tire
Eliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5x2.6"
