2024 Specialized Tarmac SL8 Pro
7.300,00 €
7.300,00 €
  1. Negozio
  1. S
  2. M
  3. L
  4. XL
  1. Elettrica
Madrid Madrid, Spain
FrameTarmac SL8 FACT 10r Carbon, Rider First Engineeredâ„¢, Win Tunnel Engineered, Clean Routing, Threaded BB, 12x142mm thru-axle, flat-mount disc
ForkFACT 10r Carbon, 12x100mm thru-axle, flat-mount disc
HandlebarsRoval Rapide Handlebar, carbon
StemTarmac integrated stem, 6-degree
TapeSupacaz Super Sticky Kush
SaddleBody Geometry Power Pro, hollow titanium rails
SeatPostS-Works Tarmac SL8 Carbon seat post, FACT Carbon, 15mm offset
Front BrakeShimano Ultegra Di2 R8170, hydraulic disc
Seat BinderTarmac integrated wedge
Rear BrakeShimano Ultegra Di2 R8170, hydraulic disc
Shift LeversShimano Ultegra Di2 R8170, hydraulic disc
Front DerailleurShimano Ultegra Di2 R8150, braze-on
Rear DerailleurShimano Ultegra Di2 R8150, 12-speed
CassetteShimano Ultegra, 12-speed, 11-30t
CranksetShimano Ultegra R8100 with 4iiii power meter
Chainrings52/36T
Bottom BracketShimano Threaded BSA
ChainShimano Ultegra, 12-speed
Front WheelRoval Rapide CL II, 21mm internal width carbon rim tubeless ready, Win Tunnel Engineered, DT for Roval 350 hub, DT Swiss Revolution spokes, 51mm depth
Rear WheelRoval Rapide CL II, 21mm internal width carbon rim tubeless ready, Win Tunnel Engineered, DT for Roval 350 hub, DT Swiss Revolution spokes, 60mm depth
Front TireS-Works Turbo, 2BR, 700x26mm
Rear TireS-Works Turbo, 2BR, 700x26mm
Inner TubesTurbo Ultralight, 60mm Front, 80mm Rear, Presta valve
Weight7.16 kg
BicycleTribe
Altro da BicycleTribe
