bis
Leggete questa discussione ... in cui un certo riccardo1 parrebbe aver risolto.
http://forums.cervelo.com/forums/t/14494.aspx?PageIndex=1
Montata piega nuova e nastro lizard skins....mamma che grip,ma esteticamente preferivo il fizik con logo,forse perché il materiale con cui è fatto il lizard lo rendono un più lucido..plasticoso.
Vedremo anche come si comporta con l'usura.
...chiedo scusa e me ne vergogno, puoi tradurmi la parte essenziale?
Non so una coppa di inglese [emoji24][emoji24][emoji24][emoji24]
vedo costa 30 euro il lizard skin
ci nastri il manubrio una volta sola immagino, giusto ?
All, I can report that my bikes noises have stopped since i received my crank back from rotor. Apparently cervelos take specific spiders as previously mentioned, if they are adjusted outside of the factory in any way they cause clicking noises, this comment came straight from rotor. They have since re-installed the spider to factory specifications, first 100kms and so far not a sound. My cervelo is a r5 di2 2014 model with a rotor 3d+ mid compact crankset. Hope this can help others as we always assume its the BB itself. I will give a follow up post after 500kms.
In questa parte dice che rotor conferma che cervelo usa uno spider specifico che se se viene modificato una volta uscito dalla produzione, causa rumori.
Morale, resa la guarnitura a rotor, ne ha ricevuta una che dopo 100km non ha evidenziato il problema. Ha una r5 di2 2014 con rotor 3d+.
Yes i can report that after close to 2000km, with the odd click and creak here and there the problem is gone. The crank was replaced by ROTOR, reinstalled with a new bottom bracket and the use of loktite compound. Apparently like previously stated the cranks have caused a few problems for some people.
A frustrating problem to have, a number of 2014 r5's that i know of that ride in my group have had similar problems from bottom bracket or crank, at the end of the day its a tollerance issue, one you wouldnt expect to have when buying a top end bike or component.
Qui dice che dopo 2000km il problema dei click e' sparito.
Aggiunge che dopo la sostituzione fatta da Rotor, hanno reinstallato un nuovo BB con la loktite.
Chiude ricordando che altri nel suo gruppo con le R5 lamentano lo stesso problema e ... si dice sorpreso che un porblema simile (di tolleranze) si possa riscontrare su una bici top di gamma.
Io l'ho interpretato come ... se monti uno spider rotor diverso da quello con l'adattamento per cervelo.ma che vuol dire "spider modificato una volta uscito dalla produzione"?
Non ho alcuna idea su quale sia la modifica che, stando al post del tipo, rotor dice garantire la compatibilita' con cervelo.In che senso?... Se è per BBright è corretto altrimenti non monta.
Sarebbe interessante scoprirlo perche' il dubbio che piu' semplicemente il tipo avesse una guarnitura bacata e ne abbia ricevuta una in ordine, resta.
Da notare che ha anche cambiato il movimento centrale.
Io la rotor l ho montata successivamente, avevo preso solo il kit telaio S3,mmm quindi come si supponeva tutti è proprio rotor che da problemi,ma ci sarà un kit da prendere per risolvere?
forse mi è sfuggito qualcosa.......chi è l'utente a cui sono accaduti questi inconvenienti con Rotor con spider spesso +11mm,quindi senza distanziale conico lato guarnitura?A me che Rotor abbia tirato fuori una guarnitura con lo spider più spesso appositamente per Cervelo dava da pensare, ma a quanto pare i problemi si manifestano anche in questo caso.
