2.299,00 €
- Negozio
- Tipologia
- Bici da corsa
- Taglia
- M
- Materiale telaio
- Alluminio
- Classica/elettrica
- Classica
Napoli Campania, Italia
Cannondale CAAD13 Disc 105 Stealth Gray Taglia 54
This is the speediest, smoothest, best handling, finest performing aluminum race bike on the planet.
- Bottom Bracket
Cannondale BB30
- Chain
Shimano HG601, 11-speed
- Crank
Cannondale 1, BB30a, FSA rings, 50/34
- Front Derailleur
Shimano 105, braze-on
- Rear Cogs
Shimano 105, 11-30, 11-speed
- Rear Derailleur
Shimano 105 GS
- Shifters
Shimano 105 hydraulic disc, 11-speed
Frameset
- Fork
BallisTec Carbon, SAVE, 1-1/8" to 1-1/4" steerer, integrated crown race, 12x100mm Speed Release thru-axle, flat mount disc, internal routing, 55mm offset (47-54cm) 45mm offset (56-62cm)
- Frame
SmartForm C1 Premium Alloy, 12x142 Speed Release thru-axle, flat-mount disc, integrated cable routing w/ Switchplate, SAVE, BB30a, Di2 ready
- Integrated cable routing w/ Switchplate
- SAVE
- BB30a
- 142x12 Speed Release thru-axle
- Di2 Ready
- flat-mount disc
- Headset
CAAD13, integrated, 1-1/8" - 1-1/4
Ruote
- Front Hub
Formula CL-712, 12x100mm centerlock
- Rear Hub
Formula RXC-400, 12x142 centerlock
- Rims
Cannondale RD 2.0 Disc
- Spokes
Stainless steel, 14g
- Dimensioni pneumatico
28
- Pneumatici
Vittoria Rubino Pro Bright Black, 700 x 28c
- Wheel Size
700c
Brakes
- Brake Levers
- Brakes
Shimano 105 hydraulic disc, 160/160mm RT54 rotors
Components
- Grips
Cannondale Bar Tape, 3.5mm
- Handlebar
Cannondale 3, 6061 alloy, Compact
- Saddle
Prologo Nago RS STN
- Seatpost
HollowGram 27 KNØT, Alloy, 2 bolt clamp, 330mm, 15mm offset
- Stem
Cannondale 3, 6061 Alloy, 31.8, 7°
Extra
- Extra 1
Removable fender bridge
